SignUp Now!The turbo is really just too big for your needs now. There is nothing wrong with the turbo itself when you have a motor that can handle it.Thanks guys,
Those links seem to be pretty helpful! Out of my curiosity is there anything wrong with running the PTE6266 turbo at some point?
Thanks,
Cam
Stay away from a 6266 until down the road when you have enough air to move it (heads) and a convertor to spool it...
Thanks ZNix, What upgrades would you recommend that I need before I would go with something like that? Just trying to get an idea of what it takes to run something like that.
Thanks,
Cam
A turbo like that would like a GOOD stall converter and a motor that can move a ton of air. A set of ported heads, ported intake, and a decent cam. The motor would need to be built to support the kind of power it can make. Bison can chime more in on this, but I wouldn't doubt that turbo is good for 132mph in the 1/4. The fuel system is also going to be important. A double pumper set-up would be able to feed that beast. You can run this turbo on a stock motor, but you are going to probably need at least a 3200 RPM stall converter to get a decent spool out of it with stock heads and intake. You would be running it below its efficiency range in the mid 11's.
Out of curiousity, anyone know how quick a TR could go if you were to run a twin stock turbo setup? Would it be pointless, a waste of time and money?
Like i said, it was just an idea floating around in my head.
Can be done ive seen it, need a lot of coin but tuning would be the biggest problem, they got the COOL factor but on a v6 you will go faster with a single turbo..Out of curiousity, anyone know how quick a TR could go if you were to run a twin stock turbo setup? Would it be pointless, a waste of time and money?
How much extra strain would it put on the engine and transmission with twin stock turbos?
I'm not doing it, just an idea that reared its head in my brain.
Like i said, it was just an idea floating around in my head. But was curious what the outcome would be if it was attempted.
Bingo...and a 6266 at 18-20psi is only running about 40-50%, right now you would be better with a te-44, te60, 60-1 or even a pt5858..A turbo like that would like a GOOD stall converter and a motor that can move a ton of air. A set of ported heads, ported intake, and a decent cam. The motor would need to be built to support the kind of power it can make. Bison can chime more in on this, but I wouldn't doubt that turbo is good for 132mph in the 1/4. The fuel system is also going to be important. A double pumper set-up would be able to feed that beast. You can run this turbo on a stock motor, but you are going to probably need at least a 3200 RPM stall converter to get a decent spool out of it with stock heads and intake. You would be running it below its efficiency range in the mid 11's.
And don't for get to put some ZDDP(zinc) in this motor.....dam this thread is getting long![]()
Thanks, I will check into that. IS it okay for this thread to be long or would it be better if I split things up and made individual threads?
Cam
It's fine. Just keep track of everything that's been said lol.
