I have a possible answer to the secret. My answer is that the intake flows way more cfm at the stage of porting it has then the heads can flow and having it that way will definitely leave room for some variation on the install without having a restriciton at the head port opening. I recently worked on a car that had GN1's (unported) and a supposedly ported intake. Guess what the intake was stock untouched. The car was very strong with the stock untouched intake. Im under the assumption now that the stock intake with just a little cleanup around the port exit/injector boss nets 95% of the potential flow unless you modified the port and raised it. The way the port slopes down opening its limited on volume/size in that area. Couple pics of welded up raised runners on stock intake. This would probably cause a big misalignment with most stock ported heads.
You are right on the money...:biggrin:
I have mentioned this before and was told i'm crazy and didn't know anything about cyl head/ intake flow.
Those heads sure are purdy ! i have looked at them up close. very nice work
Khai
what type of flow bench do you use and do you flow the heads @ 28" of water
