Mease Performance
Performance Fabrication/Supporting Vendor
- Nov 22, 2002
Gauging interest on two prototype stock location intercoolers we are currently testing:
First intercooler is the smaller of the two versions, built for optimal ground clearance for use on Buick owners with terrible driveway entries and of course for the TTA (identical bracketry) core will be efficient to the mid-high 10 second area.
As compared to our current 13, 15, 17, and 20 row units this unit will have the same ground clearance as the 13 row unit and have the same efficiency +some compared to the CAS V4 intercooler unit. This unit is equipped with our standard 2.5" inlet neck and a new 3" outlet, a 3" mandrel bent aluminum uppipe will be included with each intercooler as well as your choice of transition hose or straight 3" coupling dependent on whether you are running stock, 62, or 70 mm throttle bodies.
Second of the two intercoolers will be the largest stock location intercooler (air-air) on the market, core is proven effective partway into the 9 second territory, and ground clearance will be the same of that as compared to or 17 row unit. this intercooler will be available with either a 2.5" or 3" inlet neck and new 3" outlet, will also include 3" mandrel bent uppipe with your choice of couplers for the TB end.
All intercoolers will include a large powdercoated sheetmetal adjustable intake shroud available either WITH or WITHOUT swaybar notches, new relocated passenger side intercooler bracket, powdercoated uppipe (3"), hoses, and couplings (as necessary).
Intercoolers will be available bare (no finish) for maximum transfer efficiency, or in a flat/satin black finish for optimum efficiency while still offering corrosion protection. NO INTERCOOLERS WILL BE POWDERCOATED!!! as powdercoat is an INSULATOR and is not very effective at all on intercooler cores
Please post here if you are in the market for an upgraded stock location intercooler and if one of these units will fit your needs!
have a great weekend!
<KM@>MPE
<KM@>MPE
