REGALTURBO
I Am The Master..Master..
- Apr 20, 2003
After just installing your system and working out some bugs you can count me in on one. I`ll be calling you for my order.
SignUp Now!I think Julio should have a couple of the set up's to loan out.![]()
What do you think?![]()
Oh, I wasn't thinking about alkycontrol setting up a lend/lease program, but Rather Rick buying one,me borrowing it,and him forgetting who he lent it to.
:biggrin: :biggrin: :biggrin:
Things are moving like Molasses. So far cheapest quote has been 6K for the mold. :frown:
I have like 5 tanks out at different places getting quotes. I need to find a blow-moulder thats hungryMay need to find a contact and send one to China.. but i'd really hate to do that. :redface:
Thanks all on the tester.. I'll do an initial run of 12 next week.
Back to work![]()
Julio,
I had 2 3D Mold making mills delivered today and am going to look at a blow molding machine next week. I will let you know. Only good thing about everyone going out of business around here is that machinery is getting cheap.
Mike
Great news to hear Mike.
Jerryl, we cant measure volume.. but can measure pressure with the gauge. What i've been doing is putting these smaller gauges on the same line as my large calibrated gauge and running them up on pressure. ..............
Julio,
Correct me if i'm wrong, but the M15 nozzle is the only thing that allows your tester/pressure gauge to see any pressure? Is that correct?
What i am trying to say is that if you did not have a nozzle on the end, but rather a open hole, then there would be no pressure to build. Or is there some sort of valve within the main piece of brass?
I really like your idea here. Instead of having something wild to measure flow to verify if the pump is working, you use back pressure.
AWESOME!!!
Lastly, at what pressures (with the knob set at 8 and using Alcohol) do you recommend rebuilding the pump or replacing it???
Yullose... same issue as above.. a healthy pump is just that whether one or 3 nozzles are in place.
Would this work if I run a devilsown box that uses the stock MAP for boost reference?
I have a suggestion on the overflow/alky bottle. Make it with a wedge/baffle in it down near the bottom; so that if the bottle is getting low on alky that the molded in angled baffle will keep "enough" alky down at the bottom so it will not suck air on a hard pass.![]()
Already in place becuase of the diameter and length of feed hose used. Thats a 3/8 hose that is 2.5 feet long. If you consume 1 ounce per second, that hose supports more than a few seconds worth
Now to have a Regal tank injection molded is cost prohibitive. 7k for a basic mold plus the run of hundreds of tanks at $$$ per tank.
