Isac
No offense but why have such a high tech alky controller with such an obsolete radio/8 track/tape deck or whatever that is
Here's an easy way to make cheap mounting brackets for it with simple parts, ie. hardware store brackets about $4, a hammer, and a metal surface I used a large vise to do bends and hammer on. Simple blacksmith work.
I'm sure the showcar pros could do them in hammered copper or gold plate.![]()
3" I believe right angle brackets one side rebent to go around the ISAC the other bent upwards slightly to slide into the gray material under the radio pod.
Mine holds without any screws and doesn't slide anywhere mostly due to all the wires from the harnesses behind it.
Had to drill the mounting holes to match the existing case screws and they were reused with some star lock washers. Easy stuff.
They could be painted black and wouldn't be noticed at all even from a side view, but then again I'm rarely down on the passenger floor looking around at the radio pod.
Oh yea, the coil cord and most of the dirt is gone another plus of installing an all in one product.
