NEW PTE Entry Level Turbos!!!
Hartline Perf.
Look for a Cost Effective Buick Turbo......well here you go!!!
PTE's NEW Buick Turbo Regal/Pontiac, Turbo Trans Am specific units give racers additional options in regards to turbine wheel size, horsepower output and also expand the Entry Level line to fit a wider range of applications.
TA60 (Turbine Wheel) T31 76 trim (Compressor) 59mm inducer = $ 649.99
TA52 (Turbine Wheel) T350 76 trim (Compressor) 59mm inducer = $ 649.99
TA54 (Turbine Wheel) T04 69 Trim (Compressor) 59mm inducer = $ 649.99
These Buick/Pontiac Entry Level turbos feature a special "stock appearing" compressor cover and come standard with a .63 A/R 3-bolt inlet turbine housing; there are slight differences between the three in regards to turbine wheel trim size. The wastegate actuator will be sold separately and there is no core charge for these three turbos.
Call us Today to get in on this DEAL!!!! ;)
