Racetronix
- Oct 1, 2001
Can you get the hanger with the digital dash sender or does that have to be purchased in addition to the assembly with the analog sender?
The DS comes pre-installed for the extra $.
SignUp Now!Can you get the hanger with the digital dash sender or does that have to be purchased in addition to the assembly with the analog sender?
How much up will this support? Ready to order
what do you have or what should be used for a LS3 swap in a monte with a GN fuel tank
the motor is a 408 and could make 600 hp.
thanks
I have your sender and 255lph. If i want to upgrade to the 340 is it a direct swap out?
I just ordered the FPS - G7RXP340M with the sending unit....Will my stock return line be ok with this pump???
Sorry but stock lines even with all fittings drilled out wouldn't work for my car. Had to run -6 returnI just ordered the FPS - G7RXP340M with the sending unit....Will my stock return line be ok with this pump???
Well my Bailey chip calls for 45 as a base line so crossing my fingers although I want to run braided -6 line anyways.. Hoping it can wait till next summer....That's what I did lowest I could get fuel pressure was 45 psi. I didn't mind running new return line because so far the pump is awesome
Answer my email dangit...I need a fuel guage sending unit and pump!!!!! Digital dash 85 Gn (fully converted to 87 drivetrain). My stock guage sending unit resistor wire is broken so the guage doesn't work...and I don't trust my old Walbro 340M (even though I discovered the hose from the pump to the bottom of the sending unit assembly fell apart quickly after driving it after it sat 10 years). Already dropped the tank and would like to put it back together with a working guage AND a working pump.
I can't seem to find an answer for this question on the Racetronix website so I will try once again to get some clarification. The website lists the ANALOG sender for 15 dollars separately from the pump assembly. Which sender unit ships INCLUDED in the assembly? I have a digital dash car and I dont want to have to buy 2 separate sending units. I already have a functioning Walbro 340M high volume pump and already have a hotwire kit so I only want to replace my hanger assembly and sending unit. If I buy the SS hanger assembly that is listed for $98 dollars which sending unit will it come with...the analog one or the digital dash one?
