Congrats on the times. Very impressive car. You are definitely there and if the track is right at BG, 6s should be no problemo. I remember talking to Kenny about a year and a half ago about the GT42s. He called wanting to pick Harrys brain but Harry wasn't there. So he picked mine.
Those turbos are excellent in a twin configuration, only thing I can recommend is to make sure you have large enough blow off valves (Plural x2) because I had customers report issues with the screw on compressor wheel GT4294R and GT4202R on single rotary applications. Seems they were running small Tial 50mm B/O valves and when transitioning from WOT to shut down, the wheels were coming unscrewed and exiting the vehicle.
Look out!!!
They installed the large Pro Charger B/O valve and their problems went away. Now, given these guys were running insane boost levels, but this is something that I recommend to anyone who runs a turbo that has the compressor wheel that screws onto the shaft. We did not have any reported issues with the bolt on wheel equipped GT4276R. One thing you can do to keep an eye on them would be to use a permanent marker and mark the position of the wheel in relation to the center of the turbine wheel shaft. Check them with a mirror between rounds after they have cooled down. Just a preventive maintenance tip. It's happened and I would hate to see it happen to such a fast Buick.
Those new GT4094Rs do look to be a killer setup for a street driven car with twins, the only thing I would recommend would be to keep an eye on back pressure as there are limited to only 4 Garrett turbine housing options. (.85, .95, 1.06 & 1.19 A/R) The kicker is, they are divided Tangential T4 styles which could become a restriction at higher boost levels. On a Stage II 274+ setup, I would go straight for the 1.06 A/R housings because of them not only being divided housings, but also because they are dual bb. And on a SB V8 I would go with the 1.19s.
TurboByGarrett.com - Catalog
Two of them should be good for around 1400-1500 hp to the tires with decent street manners. PTE does indeed make standard T4 Tangential un divided turbine housings for that turbo, if in fact it has the exact same GT40R turbine wheel and the housing bolts to the CHRA the same. If so, those should be available in .68, (TH6840R) .81 (TH8140R) and .96 (TH9640R) If you wanted to run the PTE housings on a S2 274+, then I would go with either the .81 or the .96s, depending on the rpm range of the motor and if 1/4 or 1/8 racing.
I can't wait to see the Blue car run at BG, I wish you guys the best of luck.
Patrick
