EFFNQWKWE4
- Nov 6, 2002
Just got my Scanmaster2 all hooked up, and I'm learning more and more each day. My questions are mostly with the O2mv and knock readings. My 02mv jumps around like crazy when I'm just cruising. It moves anywhere from 110 to 860. Is this normal? I understand that it is constantly reading the info, but it moves around so inconsistently, it just doesn't seem right. Second question. I'm showing a trememdous amount of knock retard when I mash the gas. The highest reading I got was when the boost hit 14psi in 1st gear--16.5degrees! The 02mv reading was at about 750ish. I have since turned the boost WAY down, as I am still running the stock fuel pump(for now). All of this info is on how I run the car every day....93 octane pump gas. I have an ATR pitbull chip in it, 10mm plug wires, adj fuel press. reg., adj. wastegate, Hooker 2.5" cat back exhaust. Any help figuring this stuff out would be golden to me!! Thanks in advance!!
