i'm going for it!
i got my pump today, a little smaller than what most of you guys run, but i got it at cost so i can't complain, it should work for me.
2088-403-144
2.8 gph
5 amps
45 psi
smaler size, easier to mount.
my question is on the pump side there is the screw that i would think is for the pressure, only it says "adjusts shutoff only---does not change flow or operating pressure" also there is something that looks funny with teh wireing. the ground goes into the motor like it should, but the hot goes into the pump side, back out then into the motor. i'm wondering if this pump is ging to work for me? 45 psi surely isnt' enough and if i can't turn it up then i'll have to return it.
will it work?
also why does it say not for use with flamable liquids? methanol is flameable last i checked.
2088-403-144
2.8 gph
5 amps
45 psi
will it work?
