limitedv6
Stage 11 in the work's
- May 5, 2007
OK I have a new never touched steel crankshaft it is a offshore crank from RPM crankshafts you can look them up online it is a stock stroke.
I also have a std-std turbo buick crank that will need to go 010-010 at the very worse case I know I need to list a price so here goes
steel crank $650.00
stock Crank $200.00
WILL TRADE BOTH CRANKS FOR A NEW 3.625 CRANK Full throttle has them for $750.00 I don't care if you can get a deal on a stroker crank or whatever
I will also trade for a used wide journal crankshaft it could be a 3.590 or 3.625 but no repaired or welded cranks just let me know what you have Thanks
steel crank $650.00
stock Crank $200.00
