turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
2 TO 5 PSI WILL NOT GET IT DONE![]()
I have to agree. Once the car is hooking at 2-5 psi launch then turn it up
SignUp Now!2 TO 5 PSI WILL NOT GET IT DONE![]()
I have a TT chip, i will pull fuel out of 1st, and see if that works.
murphster--What a/f ratio do you suggest at launch and 1/2 gears?
I dont see how people are saying its rich when he got a 1.8 60 leaving at 0 PSI. Thats not bad.
Is this a TT alky chip?
Yeah it's a Alky Chip. I havent been leaving with any boost for fear of breaking something, or Leaving the road! The car go straight with what i have done. I just installed new header so it builds boost easy!
60ft=1.88
330ft=5.00
1/8 mi = 7.50- 99.5mph
1000ft=9.63
1/4mi= 11.43-125.5 mph
Trap RPM aprox 5800-6000
Launch 0 boost
slicks= 10-12 psi
starting boost at 21 turn up to 24
O2 aprox 820 at end of run
Timing .25/.23 Oct 3gal 116 to 8gal 93
What can i do to get to 10.90s???
I would have to agree with Jay-c if you left with 0 boost thats not bad,here's what I done in November I had similar # but was leaving with about 4lbs of boost went 7.20 at 100mphthis was with a 10inch PTC since then I have changed to a 9.5 havent went back to the track yet but I can build about 10-13lbs on the foot brake and launch practicing a lot more wouldn't hurt also BTW what kind of converter are you running.60ft=1.88
330ft=5.00
1000ft=9.63
Launch 0 boost
slicks= 10-12 psi
IMO -Put a loop and new U-joints, leave with 5-10 psi assuming you hook high 10s.
Yup. Solid U-joints. I went for some Moser axles too.
x2 on coverterYour converter is not doing its job up top and you need a wideband device to get some accurate a/f info. 60' sucks also. You need nothing but traction to see 10's but looking at the trap rpm you should be deep in the 10's with the correct converter and traction
