M
Magnus357
Guest
I'm planning to build up a Turbo 3.8 in the near future. The engine is eventually going to go into a 3rd gen RX-7.
I think I'm going to try to buy a whole turbo 3.8 engine used at this time to save money. Either newly rebuilt or needs to be rebuilt. If it needs to be rebuilt or even for the rebuilt engine what do I need to look at? Steel mains? ARP studs and rod bolts? What compression ratio should I look for and should the pistons be forged?
I'm planning on running a TE44 turbo, with a 61mm throttle body, 50lbs injectors, Racetronix fuel pump, and a custom chip. What fuel regulator should I use?
Not totally sure yet, but I think I may go with worked heads and cam.
I'd get a simple set of heads with the 1.77 intake polished chambers and harder springs. I'd want about a 207/207 .444 cam on what LSA though?
I'd obviously be using all the stock parts for the ones I'm not buying new.
What all would I want to upgrade esle on the engine? Intake manifold, exhaust headers, down pipe? I'm new to turbos and I'm still learning about all of this.
Also what size intercooler would I need to run keeping in mind the RX-7 has EASY front mount options?
When running a alcohol injection systems on this car with a good tune in it what do you think 93 octane power levels could be?
Either way, when I get it into a 2700 RX-7 it's going to move!
Thanks for all you help, I know I ask a lot
- Matt
- Matt
