SignUp Now!Did I mention to Jeff the other day that I broke an axle when I launched?![]()
There was a slight mess when the car made a hard left turn across the 60' lights and bounced off a new Honda.![]()
New 33 spline axles and header panel should be here next week, so I can go play again soon!![]()
Nick. If you have any great aspirations for the car, you should go to 35 spline, since you're having to do the upgrade anyway.
If Nick is still using an 8.5 then he has to use what he can. Actually, I use a 33 spline also. It's just that I've been seeing evidence from other racers at the track that 35 spline would be better for a 8.50 capability. After doing some checking on it too, a 35 spline is more suited.Don,
I think 33 spline is as big as you can go with an 8.5" rear. Cal ran in the mid 8's with this setup.
Jeff
Don,If Nick is still using an 8.5 then he has to use what he can. Actually, I use a 33 spline also. It's just that I've been seeing evidence from other racers at the track that 35 spline would be better for a 8.50 capability. After doing some checking on it too, a 35 spline is more suited.
Yeah, a 33 spline will get you by, but then, you can do 8s with a 109 block too.
