xpander343
- May 17, 2006
You got the 7/32nd bolt out holding the speed sensor onto the back of the cluster?  Looks like your speedo cable is unhooked.  Since you have a column shift like me make sure u unhook the cable for the gear selector off the steering column.  You may need to adjust it where you put it on the column on reassembly.
		 a
	a
That black connector is in the radio hole and attaches to the big white connector. On mine I had to pull the radio to get at it.
