http://www.vortexbuicks-etc.com/ignition_switch.htm
the Scanmaster reports the voltage the ECM tell it to. It doesn't actually act as a voltmeter. Any voltage drop between the battery and the computer is what you're seeing on the display.
So I took my multimeter and went from neg battery to the nut on the back of the alternator and got 11.8volts... Now I did have my alternator tested before and it tested good... This is the stock alternator, so does this mean its bad?
If so what alternator should I install?
Thanks!!
