I installed a nitrous kit on the t-type a few weeks ago. The results are incredible.
From the outset I simply wanted something to help spool my turbo. My combo is a little laggy with the stock long block and TE45A. I also really hate having to spool the turbo at the line at the track with the transbrake. I much prefer pulling up and just foot braking it a few rpm and stabbing the throttle.
Ever since I installed my GEN II translator I wanted to use the auxiliary output to activate nitrous to spool the turbo and turn it off before full boost.
So I purchased a super cheap sniper nitrous kit, 75-125 hp and installed it with the GenII logging MAP signal and triggering the nitrous at wot no boost, 3000 rpm and then shutting off the nitrous at around 15 psi.
I started with the 75 and after a few blasts with that I stepped up to the 125.
It is nothing short of incredible. The second 3000 rpm hits the tach suddenly jumps almost instantly to 5 grand. I now have uncontrollable wheelspin on these weak BFG radials im driving on since one of my DRs was punctured.
I can pretty much do John Force burnouts from anything under 45 mph. I haven't stayed in it long enough to know how far it will keep burning the tires down :biggrin:
The only problem is that this cheesy kit doesnt come with a pressure gauge much less any kind of bottle heater. From what I see from my nitrous addicted LS1 buddies, an ambient temperature bottle is usually nowhere near 950 psi that the kit is rated to run at. All the ones i have seen are usually in the lower 700s. So im guessing I have at least another 30 hp of nitrous im missing out on.
And at this rate, the 10 lb bottle should last me a very long time considering the fact that I am only spraying it for less than a second at a time.
