BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
Ok, i pretty much have the physical install aspect done, now some wiring questions..
1. Do i use the new MAP sensor (supplied with the controller) for both the FAST and The controller, or do i use the original 3-bar GM MAP for the FAST system?
2. Where do i get a signal for the activation? I'm using the transbrake for the clutch signal, is this correct?
3. Do i plug the remaining holes in the solenoids? I lpumbed the solenoids as instructed, and it says to plug the exhaust port of the increase solenoid, but do the EXH and OUT of the decrease solenoid stay open?
4. Does the solenoid polarity matter?
Just waiting on this info to go and try it out!! Thanks for any help you can give guys!!!
