No air conditioning with XFI
jdpolzin
How do I get my AC to work with this XFI? The fan blows but I dont think it's engaging the compressor. Any help?
Go to "View/AC Clutch Control" and make sure the parameters are correct.
When you go to the screen it will be clear. There is a max coolant temp that will shut it off and a max TPS that will shut it off.
No, it is all incorporated into the adaptor harness. Are you sure you have enough freon?
you can try to unplug low side sensor on the evaporator and jump it with the a/c switched on the heater control head...if the a/c then turns on your charge is too low
-dan
