TurboMonte 2
Car Nut
- Mar 21, 2006
1) If you would list your "build" in signature (or at least all in one place) of your car in question, it would certainly help ALL trying to help you,,,
2) You went way-too-far with this problem w/ using only an in-dash boost gauge (notoriously innacurate),,,
3) Also hope your 5500 rpm reference is NOT with in-dash gauge,,,
4) You're way off-base with regard to too-high a vacuum preventing quickness into boost--you can neither effectively control it nor would it have your anticipated impact,,,
5) A front-mount IC will normally affect/ slow your spool-up rate once you've launched--but not significantly beforehand,,,
6) Boost/ RPM/ Stall are related to engine HP/ TQ generated,,,
7) Your problem(s) is(are) not really related to rear wheel cyl size or 2X long rear shoes,,,
8) Basically, your converter is too loose/ sloppy for your "build"--& is even possibly "out-of-whack/ defective"...
