no crank issue
LS1ZIGG
Banned
ok so i checked the grounds behind the head-good
checked for blown fuses-none
checked power to the ecm-good
checked wires to the starter-all getting power except the purple one
what else do i need to check for im kinda stumped here
Does it even click when you turn the key or do you get nothing? Did you check the battery terminals. How about the orange ECM plug by the battery? How about the fusable links?
yes i checked the fuses there all ok, the car doesnt click but all my gauges and scanmaster turn on,the orange wire has power and the terminals are on nice and tight
Might want to give Lou at Lou's Auto repair a call. (949) 378-1590, I believe, in Lake Forest. He can have that running in no time.
If the engine does not spin over, starter is prolly bad.
Try tapping on the starter case with a hammer while someone else turns the key. If it then starts, replace the starter.
Does purple wire have power with key in start position? Did you try to jump the starter with a screwdriver to see if it spins? Let me know as I had that problem & fixed it.
