turbocaddy1982
- Sep 10, 2005
ok, driving home my trans goes into neutral, have no reverse or drive,does not feel like it's going in, oil is full, where can i start to check...pull a trans cooler line to see if it pumps?,change out oil and filter? the last time something like this happened, was when the drivetrain was new...under 1,000 miles,the converter hub blew up and wrecked the front pump..think this happened again?...it's in a 82 caddy coupe deville and it's running the stock 87 gn converter...any help can do
