monkeyy337
- Aug 27, 2007
I'm trying to help out a friend who just changer over his 85 hot air car to a inter cooled system. The problem is there is no spark at the spark plugs so of course the motor will not fire. Just to explain what has been done/checked so for:
1. A new motor was installed.
2. The computer and wiring harness have been changed to a 87 GN configuration.
3. The crank senson has been changed 3 times
4. There is current down to the crank sensor
5. There is fuel pressure.
6. The engine turns over fine but will not fire, no spark at the plugs.
7. Engine and other item ground wires are installed and tight.
I realize I'm not give you guys much information to go on but thought maybe someone out there might have some ideas. The car was up and running with the hot air motor Monday so the car has not been setting very long. Any ideas would be appreciated.
