Having an issue with my fuel system.i have no pump prime and no injectors pulsing. Installed hot wire kit and did a cylinder head swap upgraded to 42lbs injectors and I also had a small fuel fire replaced injector harness. I sprayed starting fluid in it and it fires right up. I also checked all the fuses. I jumped b and d on fuel relay fuel pump works great got 42lbs on gauge. Injectors have voltage on one side.got any ideas??? Thanks in advance
