I am running the Postons Ultrachip Thumbwheel for the 84/85 ecm. It is set at the 4 setting. According to the paper i got with it the boost should be around 18psi............I am getting about 15psi and the rest of the gears are around 13.5psi......My adjustable wastegate rod is as short as it will go....I have a high flow convertor on the car which is probably around 7 years old at least.....I had a kenne bell chip in before and was getting around 19psi and lower...........I threw the kenne bell back in today and got a wapping 13psi and lower......rod short as it goes......i dont know what happened????? The ultrachip hasnt made the 18psi since it has been in......just isnt making sense to me!!!!
Of course that is why you guys are here
Is there a setting besides the rod that could be of that would cause a problem???????? Is it possible to shorten the rod to much? If i had a vacuum leak would I hear it..........otherwise the car is running great just went on a 4 hour round trip to graduation party and she left a very nice 75 to 100ft black mark when i did a burnout for my aunt...
TIA 1QUICK6
