Hi all. New motor rebuild with roller cam and adjustable rockers. Started priming with a 1/2" drill. Packed the pump with vasoline. Definitely feel the stress on the drill which tells me I'm getting pressure. At it for 5 minutes and no oil up to the heads. I pull off the left valve cover to make sure, spin the pump a few more minutes and nothing. Start to unscrew the oil filter and oil is coming out so oil is in the filter. Start to loosen the upper oil cooler line to the radiator and oil starts dripping out so I re-tighten. My fear is the engine builder forgot to put an oil gallery plug in. Am I missing something? Any and all suggestions are greatly appreciated. Thanks, andy
