turbocliff
I Slang in my white T
- Jul 5, 2004
Hey guys, a bud of mine has an 83 Ttype with an 87 drivetrain. It has the vacume assist master cylinder, not the powermaster. He did the rear brake upgrade with the larger shoes on both sides, as well as istalled the S10 manual brake cylinders... He had figured before he did this he needed to bleed the brakes, as there was not alot of pedal left, but now after doing this, and bleeding thw whole system, he has even less pedal left. The car stops, and will hold some boost on the line, but at cruising speeds, the brake pedal hits the floor, and barely stops the car.... It has only a filter between the intake and the master cylinder, not a check valve.
1) does a check valve need to be installed?
2) is there something else we are missing?
3) Are there problems with using the S10 manual brake cylinders without the powermaster set up?
