No reverse
c&cgn
It is, what it is...
I think I hurt something at the track today. Only made one pass but had no reverse when I got back to the pits. Spun the tires off the line... not sure if this has anything to do with it or not. I drove it home with no other issues. All other gears seems okay... I just couldn't find a reverse gear at all. What do you think it is???
Probably knocked the low-reverse clutch out of commission. You can test that theory by pulling the shifter from manual second to manual low while rolling along (off throttle) at about 15 mph. If the low-reverse clutches are working, you'll feel some big-time engine braking when you pull the shifter back.
