bama-t-type
- Aug 11, 2008
Had to have turbo rebuilt so the car set up for about 6 months.
the trans shifted perfect before but has no second gear now
any info would be helpful
is there anything in the valve body that could cause it? It has no second gear at all goes from first to third. If you put ****er in second it will run in first untill you let off gas then it nutralizes untill you get the rpms back up to were it would be in first if that makes any sense. leave it in drive and once you get rpms high enough for it to shift out of first about 3500 it goes to third. ANY HELP WOULD BE GREAT THANKS.
