D
Dave85
Guest
I reacently installed cam,lifters,pushrods,and timing chain. I had spark to all cylinders before I did this and now I'am getting no start. Fuel pressure is there, cam position is set but the window is facing the 7"o clock position the plug/cap is on the driver's side. My crank position sensor was looking pretty rough as in dirty I ended up reusing it. What is the proper why to install and check them? I have no spark. My coil pack is good not sure about the module but it had spark before this. The timing marks on the sprockets where lined properly. Just trying to get some ideas together. Thanks
Dave85
Dave85
