getdowngranny
Mr. Fix It
- Jan 8, 2006
Straight to the point. Replaced powermaster with hydroboost and also replaced the speedometer cable.
No fuel prime. No SES light when you turn the ignition on. Therefore no start.
Scanmaster shows version then goes blank. Telling me the ecm is more than likely not getting power.
Gen2 translator powers on.
All fuses on the fuse block have power on both sides.
All fusable links test good.
I have spark for some reason.
If I jumper the fuel pump, I still have a no start with spark and fuel.
I'm pretty sure it has something to do with the work performed in the area of all the wiring.
Any direction would be greatly appreciated. Or a readable wiring schematic. The one I found on gnttype is almost unreadable.
Thank you.
Thank you.
