Young84Ttype
- Aug 13, 2012
So recently did a engine rebuild and I'm in the process of trying to break in the new 206/206 flat tapet comp cam. The only problem is no spark. We troubleshoot the problem and come up with replacing the crank sensor and cam sensor cap. Now the problem is that the cam sensor cap LED turns on, but when i spin the cap it turns off. My mechanic check the fuse box and removed the ECM-IGN fuse and put it back in; and that turned the LED back on. This was the only way to turn the cam cap LED back on once it turn off from spinning it. With this happening my mechanic thinks the ignition module has to be replaced. Any thought or help would be appreciated.
