larrym
West Coast Newfy
- Jul 17, 2007
Thanks Bob the pencil mark procedure makes sense, my balancer has a file mark I put on for reference now I can double check it!
SignUp Now!in cam sensor checking mode the tach sweeps and stops at **something**, start the engine and set the sensor so the tach reads that same **something**
this will work with good tachs, bad tachs, whatever.
Bob
Measured out 1.45" on a strip of tape and then struggled for 30 minutes trying to affix that onto the balancer (I have thin fingers and still could barely reach it.) Once I got that mess figured out,
Your signatures Gif pretty much sums up the cam situation quite nicely I think. Good to know though! You coming to MAGNA this year? Up for a rematchAnother way to set the cam sensor without any of that mumbo jumbo is on here in these forums. I was taught this by a guru. There is a pointer on the outside of the timing cover cam sensor hole. Line that up with the notch in the cam sensor for the cap. Make sure the window is opposite that on the trailing side, i believe its trailing. and drop that sucker in. Obviously get your engine to tdc compression stroke.
Lol unless you can lend me some $$$$$ so I can get mine running again no chance of a rematch. Me showing up to Cecil again, most likely. Finally showed up to the monthly meet this month. Need a whole new heart for my beastYour signatures Gif pretty much sums up the cam situation quite nicely I think. Good to know though! You coming to MAGNA this year? Up for a rematch![]()
