NO START WTF
bout to do esc swap
Ok. Here's the update. Swapped out the esc with my running T & started testing wire continuity from module to ecm, I tested the 5 wires that run to ecm & the yellow wire that feeds cam signal did not give me continuity at first. After messing with it a little I finally got continuity so I plugged computer back in & went to crank it. I heard a snapping sound & realized after a bit that it was finally spark......... &&&&&& then!!!!! Battery dies! Lmmfao. After all that I end the night
With a dead battery! Lol it's all good. I think my problem will be solved but let's not count our chickens before they are hatched! Lol tomorrow I'll warranty my battery & give it a go again. I'll update you guys tomorrow. Good night
For the hundreds of threads I read & never saw the problem solved. Here I give the ****UPDATE**** that my no spark problem is solved. I checked the harness last night & found that the yellow wire on ECM side of the harness did not have a good connection. I fixed the problem & fired this baby up today!!! Sigh of relief & a feeling of accomplishment. I'm taking the rest of the night off. Thanks to all with ideas to get me rolling again.
