Non-lockup / Tbrake button ??'s
BIGAIR
Boost addict
First- have a NL convertor (and valve, of course) and just installed Lonnie's new T-brake. Can I remove all the TCC wires and switch, or does the hole from the pump need to have the "plunger" in it?
Second- anyone have a part # for a T-brake button that will work w/ this new brake?
Tried calling EA, but I know he is busy, so I thought I would ask here.
Thanks,
Lee
Thanks Boost231, looks like that is the one I am going to get.
Anyone know about the wires?
dont think you can remove the plug. some of those wires go to the 3rd and 4th gear pressure switches
That makes sense, but the guy that helped w/ the brake install said that since we removed the wire harness to place the white piece (for the button) in the trans, I did not need those anymore. I asked him what to do about the wire harness that hangs from the car that used to plug into the trans, he said to tie it up somewhere. :confused: I obviously do not know, that's why I posted, someone please explain.
TIA
