Non-lockup valve Question
flowerpower
I got a 9" 3000 non-lockup stall and I also got the transgo non-l/up kit becouse I read that all I needed to do is to take the o ring off the input shaft and change the valve...My question is that the valve is under the the l/up solenoid right?
Also take out the orifice capsule "little star thing inside the hole at the end of the input shaft" right?
Just making sure .....It looks really easy and I cant wate to feel the difference from the orange stripe to this 9".....should be :eek: ...lol.
Right. Take the lockup solenoid out. The snap ring. The retainer. Remove your lockup valve and 2 springs out and install the n/l valve and retainer and snap ring. Take oring off input and pull out ball/capsule and you are ready. Hardest part is pulling the trans out. :)
capsule
I use a 1/4 in. standard thread tap to insert in the capsule--rotate clockwise and pull--some a little more trouble than others--once you break them loose it will come out.
