Normal oil pressure for my set-up
WhiskeyGN
Just wondering what you guys think my oil pressure should be with my set up. I've got a 60 lb spring in now, so generally it's around 60, little higher under load, lower when not. Thanks.
Yea hot at around 2500 to 3000. When I'm at wot and almost to 6k it goes up almost to 80 psi.
10-25 at idle hot in gear fully heat soaked.....and 60ish cold or WOT. spring dictates max psi.
These are the basic general ranges oil viscosity will generally dictate oil psi at idle....... thicker will give you a more idling.
Big thing is that it comes up with rpm 10 psi per thousand.
