NOS PARTS
Accumulator Ball 18038507
Intake pan gasket 12328760
(3) Head gasket 25528486
Coil pack 12353801
Knock sensor 10456287
(6) 42TS Delco Spark Plugs
3.8 SFI Emblem 25519633
Boost Line Y kit
Down Pipe to Elbow Bolts with Springs GM?
NEW AFTER MARKET PARTS
Rol Extreme Cork Rubber Valve Cover Gaskets
Felpro Timing Cover and Water Pump Gaskets
Energy Suspension Poly Front Control Arm Bushings
12pt ARP Rod Bolts
Down Pipe to Elbow Gaskets
Boxed Lower Control Arms Black with new Bushings
USED AFTER MARKET PARTS
ARP Head Bolts
Low Mile Roller Springs off ESP Heads
Solid rocker shafts
adjustable pushrods...installed but motor never fired.
USED 86-87 PARTS
Stock ECM Chip
Iron Brake Drums
(7) 2 dot Rods
Set of Heads bare and clean
Turbo Shield
Maf Screen
Intercooler
Intercooler Shroud
Side Body Moldings
Aluminum Drums ready to go
All 86-87 Sensors
Intake clean and repainted used Sensors w(2) New Hose Nipples
Plenum
Plenum and Throttle Body
Throttle Cable Bracket
Flat Coil Bracket
Round Coil Bracket
Fuel Rail
Coil Pack
Coil Pack Module
(2 )Belt Tensioners
84-85 PARTS
Stock Block clean
Heads
Intake Manifold clean and repainted
Brackets
Sensors
Engine Harness
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
84-85 GM Wheels with 215/65/15BFG on front and 235/60/15 Dragradials on back
5 passes and approximately 100 miles on all tires
Newer GTA/GNX Wheels 245/50/16 Firestones 95% front 45% back with caps
and chrome lugs
