The search option didn’t work and O got tired of going page through page. So here is my issue.
On my way to the track today I did a quick pull getting into the highway like I always do, everything was fine until I let off the gas. As soon as I did that I heard a light noise like when something made out of metal falls. Then the car went into neutral, no reverse, no forward gears, just N and park. The transmission has maybe 8,000 miles and around 25 eight mile passes with the old set up (320 hp)
Shifter cable is good, torque converter was bolted fine, and no leaks whatsoever. Fluid looks normal and doesn’t smell burnt.
I would guess that the car is in the low 400 horses and maybe high 400 of torque. I dynoed a while back with miss matched chip, it pulled 320/400 @16 pounds. Since I’ve upgraded the stock parts to FMIC, 3”dp, 3”exhaust, matching chip running 25psi on 93/Alky.
Any ideas?
Any ideas?
