I finally got my car running and thought I had an artificial lean idle condition of 15.94 (the max lean) with black smoke bellowing from my exhaust. I took the car out of closed loop mode and manually backed off the values in the base VE table and adjusted the throttle blades which stopped the black smoke, which also produced a smooth steady idle. Now, the closed loop is set to kick in at slightly above idle and not to turn back off at a few hundred RPM under idle. To make a long story short I have run several logs and just can't get the O2 sensor to take out enough fuel to bring the actual A/F to the Target A/F. I have target A/F set for 14.1 in that area and the closest I can get is somewhere between 12.6 - 12.9... I have adjusted the closed loop gain all the up to 50 which did get me a little closer, but I have 83lb. injectors and shouldn't need that much gain.. right? I even tried to adjust the Max Closed Loop Step but it would only let me go to 10.
All of my global parameters are correct for my application.
The biggest question I have is why will my O2 sensor not take out enough fuel. I can smell that it is in fact running a little rich which would make sense as my O2 sensor is reading low to mid twelves most of the time.. My Aft Corr% is at zero, and my sensor is removing small amounts of fuel, just not enough to bring ther A/F to the targeted A/F (and doesn't swing back and forth). I have even held the throttle open at a constant position to make sure that I am seeing the results of accelleration, and it makes very little difference. My VE tables are not yet perfectly tuned, but the O2 sensor is not taking out the max fuel (or even close to it) that are set forth in the Target A/F Closed Loop Correction Limits..
I have also went through all of the diagnostics set forth in the FAST help section and all of my values are within spec. except for my UEGOS(v) which is 1.04v (the spec. is 1.02v). I believe I asked Tony at FAST about this sometime back and he said that it was ok to be a little high.. Does anyone know if that's true?
I'm new to all of this and am totally stumped on this one. Am I missing something obvious?
