SignUp Now!Disconnect the TQ converter and see how far it goes into the trans.. and be a good time to check that thrust.I pulled the belt and I couldn't get the balancer to move. I didn't pry real hard but it seemed tight. I talked to my engine builder this morning and he brought up a good point. He built a high end GN motor for a guy and shortly after installing the motor he took out the crank. When my engine builder took the motor apart he told the guy that something is shoving the crank forward and have his converter checked. He figured the converter was ballooning and pushing on the crank. Second time around the same thing happened again. The customer told the engine builder the converter was fine, well in the end it was the converter!
Not that this is what happened to me but I had a converter failure last year. I replaced it and away I go. The noise my motor is making now I have heard before. It was on the return road after making a pass the first time out with the old converter. It went away by the time I got to the pits. I'm new to these cars so I figured it was exhaust or something under the dash??? It concerned me the first time I heard it but since it went away I didn't think much about it when I made more passes. I drove the car a lot after going to the strip etc etc and until Saturday never had that sound occur on the street. My old converter was a restalled stock converter, nothing special like I have no so maybe I got the ball rolling with the old converter and it's taken this long to show itself.
Did you measure the distance between the converter and flexplate? Should be 0.100 - 0.150 to protect the crank thrust from damage.
