SignUp Now!If the cable was disconnected the check ball will seat and set the pump pressure at a constant 90lbs assuming the check ball is still in place. This is to protect the transmission in case the cable does break or become disconnected. If you haven't got on the car too hard the transmission should be ok.
Yes. If you didn't feel the transmission slipping then you probably are still ok.mikestertwo: "The arm must be bent out of shape. The arm should be able to push the T.V. flush with the valvebody without the T.V. plunger pushing past the arm. Also it looks like the safety checkball, liftpin, and spring have been removed from the lever assembly."
Great. Do you mean this checkball?
