(Not)the biggest parts list ever...86 T-Type part out
captrob
Slow GN Fizz!
Parting out salvage title ’86 T-Type 110,000 miles
Maroon exterior, Grey interior
Prices don’t include shipping unless specified. I don’t “jack up” charges.
Reasonable offers always accepted / negotiable.
Package deals are encouraged.
Thanks,
Rob Pahl
Keller Tx
captrob@hotmail.com
Misc:
Scan Tools
Direct scan-new board and just checked by Kent Chu w/cables, manual…$150 shipped
Turbo Link version 2.13 w/cables and instruction manual ………………$100
Laptop-old-AMD processor Win 95 or 98-works D.S./ Tlink well………..$50
CHIPS
stock 86 chip………….. ……………….$10
40# Jay Carter w/variable timing…….…$15
Thrasher stock inj. 92oct………………..$20
Thrasher stock inj.100oct……………….$20
Kenne Bell “Hot Flash” ………………..$20
Unknown ‘street 93’ stock inj………….$5
Set of (4) 87 GN wheels in good condition(but not perfect) one has dent ……… $300
Powerstroke intercooler – good shape- aluminum end tanks, 3” ports,
few dents and bent fins – packaged up – ready to ship today……………$200 shipped
ENGINE
Turbo crank – needs turned ………………………………..$150
’86 Turbo Engine harness – not hacked………………..….$250
Alternator……………………………………………..…….$50
Lower intake – ported to FP1200 gaskets………………..…$75
Intercooler – stock, has slight indention from fan……………....$75
Brackets - both………………………………….………$25 each
Intercooler fan and hardware……………………………………..$40
Turbo – stock, no shaft play………………….…………………$160
Turbo oil feed line……………………………………………….. $10
Turbo oil return line – no leaks……………………………………$20
Oil return to block, brass adapter,screws into block in front…….. $20
Crossover pipe – no dents, sealed well………………………….. $40
Downpipe + elbow – stock……………………………….………$50
Fuel rail(86-87) …………………………………………………..$50
Injector harness …………………………………………………..$40
Fuel lines – off rail to frame lines…………………………..……$70
Fuel injectors – stock – flow matched..…………………………$100
Fuel sender assembly…………………………………….…….$125
Frame fuel lines – no rust……………………………………….$50
86 GN Electric fan……………………………………………. $100
Stock Radiator – ran cool………………………………….… $50 prefer local
Radiator hold down plate………………………………………$50
EGR valve and hold down…………………………………… $10
EGR solenoid bracket………………………………………... $15
EGR solenoid – very low miles……………………………… $20
Underhood light………………………………………………..$5
GM oil pan gasket………………………………(NEW IN BAG) $20
Flex duct (MAF TO TURBO) – no leaks…………………… $15
Coil pack brackets …………………………………………..$20 each
Charcoal canister …………………………………………….$15
86 Cruise transducer ………………………………………….$10
Cruise vacuum ball…………………………………………. $10
Misc cruise parts……………………………………………..$ask
Oil cooler adaptor …………………………………………. $40
Air Cleaner scoop(86-87 Scoop for air breather) …………..$20
Air Cleaner assembly(86-87)……………………………… $30
Small K&N breather for passenger side valve cover ……….$5
Dip stick and tube …………………………………………. $40
Main accessory bracket - the big alum. one ……………….$100
Frame engine mounts……………….…………………….. $15
Rubber engine mounts(stock) – almost new……………....$50
Power steering pump……………………………………… $70
Power steering reservoir ……………………………………$50
86-87 Crank pulley with adapter………………….……….. $30
86-87 Water pump pulley………………………………….$25
86-87 Alt pulley - 2 available ……………….………….$15 each
Valve covers ……………………………………………..$40 pair
Valve cover oil filler tube and cap ………………..…….$30
SUSPENSION
I have all the complete front suspension pieces – low miles……$ask
8.5 drive shaft……………………………………………… $50
Stock springs ……………………………………………….$10 each
8.5 posi rear – 67000miles……………………………….…$750 pickup
Control arms/suspension pieces…………………………..…$ask
Sway bars - front and rear ………………………………….$25 each
86 GN Quick Ratio Steering box ……………………………$50
INTERIOR
Dark Blue T-Type lower door panels – no CS……….$50.00 a set
Upper door panels - no chrome escutheons or pull straps $75.00 a set
Gray T-Type door panels – lower – CS2…………….$100 a set
Upper door panels – no chrome escutions or straps…$150 a set
Door sill plates ……………………………………………….$10
rear package tray – gray……………………………………… $35
B pillar covers…………………………………………………$35
used carpet – gray……………………………………………. $25
Emergency brake release mechanism……………………….. $25
Gas pedal ……………………………………………………….$8
Under dash covers …………………………………….$20 a side / $35 for both
Double guage ‘A’pillar (Lotek) one has been opened up a little…$15
86 T-Type seat belt set – grey………………………..$100 for all 10 seat belts
Shifter - no T handle ………………………….…………………….$35
steering column(tilt, floor shift car)………………………………… $100
Console shifter plate - goes around the shifter ………………………$35
Console - 86 T-TYPE – gray, has a few cracks on lower panel…..….$75
Dash plaque - 86 T-Type……………………………………………...$50
Sail panels for Hardtop car ………………………………………….$50each
Seats 86 T-Type gray front bucket seats – one needs recovering …….$150
Steering wheel descent shape…………………..…………………….. $100
T-type horn center and ring – has crack………….………….…………$15
Seat Track Covers – manual -pass side………………………………..$30
Seat Track Covers –manual -driver side …………….………………..$30
Gauge surround………………………………………………………..$30
Radio surround……………………………………………………….. $20
Grey third brake light………………………………………………….$20
Glove box ………………………………………….………………….$40
HEATER/AC CONTROLER…………………….…………………..$30
Visors - gray – good shape, a little faded ……..…………………..$20 each
Rear view mirror excellent shape ………………….……………….. $10
rear seat gray-both pieces ……………………….…………………..$100
Interior gray……………………………..……ask for other availability
BODY
Blackout headlight bezels(have screw hole in them for unknown reason)$50 for both
Right side air dam – good shape…………………………………………$25
Left side air dam – has hole cut in it for cold air………………………...$15
Rear air dam…………………………………………………..$20
Rear quarter panels – prefer local……………………………………$200 each
Doors- pretty clean, very slight rust on bottom – prefer local……… $200 each
Trunk Lid- small dent above lock area – prefer local………………… $100
Hood- rust free – prefer local………………………………………… $200
Clean front fenders – cut for GNX vents………………..………..$100 each
T-type header panel – prefer local………………………………. $150
Quarter window glass with black trim …………………………..$100 each
All black window moldings- ………………………………….$300 for all
Heater/Air box- great shape ……………………………………….$75
Radiator support- ………………………………………………..Make offer
Door glass………………………………………………………… $25 each
Front bumper – painted(I think)……………………………..…….$75
Rear bumper – painted(I think)…………………………..…….. $100
Grill (86 T-type grill)…………………………………………….. $75
86 T-type grill emblem……………………………………………. $15
Lock set(all 3 locks with key)……………………………………… $60
Door mirrors ………………………………………..…………..$30 each
Black manual antenna complete with mast, base and nut……….$35
Turbo plastic wheel wells……………………….………….. $80 each
Tail lights Harness …………………………………………….$35
Bumper light trim………………………………….…………..$20 each
Hood pop cable………………………………………………..$10
Rear hood trim …………………………………………………$50
Trunk / hood latch ……………………………………………….$15 each
headlights ……………………………………………………..$1 each
Hard top seal reatiner moldings ……………………………..$35 a side $60 a pair
Rear window to trunk filler……………………………………$20
Inner fender metal liners ………………………..…………….$30 each
windshield wiper assembly …………………………………….$15
Front under frame braces………………………….……………$30
’Kirban’ Rear-seat braces – installed about 3 years, great condition … $40 shipped
complete frame complete or can cut parts off - left side front frame horn a little tweaked
complete beautiful floor pan for bucket seats and console $100 – come cut what you want
TRANSMISSION
D5 converter …………………………………………………..$50
Transmission cross member – 200 4R………………………… $40
Tranny dip stick and tube………………………………………. $40
Speedo cable……………………………………………………$20
I check the board once a day so I'll update and get PM's then.
Email me at: captrob@hotmail.com
Make offers...want to get these parts moving!
Thanks, Rob
Hey Rob,
Dannyo here, I will take the ’Kirban’ Rear-seat braces – for $40 shipped. Also, if the door window glass are in good shape, I take those as well.
We can either meet up sometime or can I paypal you and you ship or hold them for me.
Let me know either way, thanks!
Dannyo
Interested in turbo drain pipe and air breather filter for pass valve cover shipped to akron ny 14001. Let me know.Thanks. Dalton 1977@aol.com
Do you have the top dash piece, where the front speakers go? if so hows $50 sound?
Thanks,
Joe.
chips
I'll take the 2 thrasher chips for stock injectors and the KB Hot Flash chip too for $20 each.
Thanks ....... BW Jones
Mo Stuff
I'll Also Take The Stock Air Cleaner Assy And Egr Solenoid. IF THE CRANK PULLEY WITH ADAPTER MEANS THE PART WITH THE INTERRUPTER RING, I'LL TAKE THAT ALSO. LET ME KNOW ABOUT PAYMENT.
THANKS BW Jones
Those so far...
Sorry, no pull strap covers.
Do you have any pull strap covers? If so, how much shipped to 42701?Thanks.
Hey Danny,
You're the first for the back seat braces. The door windows are in good shape as far as I can tell. I haven't pulled the door panels to look at the bottoms though. I'll do that tomorrow and get back to ya. I can ship the braces to you or hold them if you want the glass too and meet up at something. Let me know.
Dalton, Drain pipe is available...$25 shipped. Passenger breather is taken already.
Sorry Joe, Dash top was pretty broken up, not usable.
BW Jones, Replied to email
I think that covers everyone so far.
Thanks, Rob
If Danster doesn't take the seat braces I will. Do they come complete with mounting hardware?
how does the rear seat look, and will you break up and sell just the seat and not the back. if so how much and to ship to st .louis?
pics of the front and rear seats ? and do you have the right rear wheel well molding thanks dale in arizona
I'll get pics of the seats tomorrow guys, front and rears. However, I'll have to look into shipping those big items.
Thanks, Rob
Do you have a front spoiler. How much plus shipping to 90003. Thanks allot.:D
Are you talking about the lower air dams? if so, passenger side is in descent shape, driver side has an opening cut in it with a cheesey screen to allow air to a cold air filter. Pic if you want one.
$40 shipped
Thanks, Rob
parts
Do you still have the radio surround? Do you have a pic? I am very interested if you still have it. Thank you
