captrob
Slow GN Fizz!
- May 30, 2001
Updated List
Parting out salvage title ’86 T-Type 110,000 miles
Maroon exterior, Grey interior
Prices don’t include shipping unless specified. I don’t “jack up” charges.
Reasonable offers always accepted / negotiable.
Package deals are encouraged.
Thanks,
Rob Pahl
Keller Tx
captrob@hotmail.com
Misc:
Scan Tools
Direct scan-new board and just checked by Kent Chu w/cables, manual…$150 shipped
Turbo Link version 2.13 w/cables and instruction manual ………………$100
Laptop-old-AMD processor Win 95 or 98-works D.S./ Tlink well………..$50
CHIPS
stock 86 chip………….. ……………….$10
40# Jay Carter w/variable timing…….…$15
Thrasher stock inj. 92oct………………..$SOLD
Thrasher stock inj.100oct……………….$SOLD
Kenne Bell “Hot Flash” ………………..$SOLD
Unknown ‘street 93’ stock inj………….$5
Set of (4) 87 GN wheels in good condition(but not perfect) one has dent ……… $300
Powerstroke intercooler – good shape- aluminum end tanks, 3” ports,
few dents and bent fins – packaged up – ready to ship today……………$200 shipped
ENGINE
Turbo crank – needs turned ………………………………..$150
’86 Turbo Engine harness – not hacked………………..….$250
Alternator……………………………………………..…….$SOLD
MAF bracket (Aftermarket-attaches to alt bracket)(2 avail)….$5
(Aftermarket-attaches to stock frame mount)…$5
Lower intake – ported to FP1200 gaskets………………..…$SOLD
Intercooler – stock, has slight indention from fan……………....$75
Brackets - both………………………………….………$25 each
Intercooler fan and hardware……………………………………..$SOLD
Turbo – stock, no shaft play………………….…………………$160
Turbo oil feed line……………………………………………….. $SOLD
Turbo oil return line – no leaks……………………………………$SOLD
Oil return to block, brass adapter,screws into block in front…….. $SOLD
Crossover pipe – no dents, sealed well………………………….. $40
Downpipe + elbow – stock……………………………….………$50
Fuel rail(86-87) …………………………………………………..$40
Injector harness …………………………………………………..$25
Fuel lines – off rail to frame lines…………………………..……$70
Fuel injectors – stock – flow matched..…………………………$100
Fuel sender assembly…………………………………….…….$125
Frame fuel lines – no rust……………………………………….$50
86 GN Electric fan……………………………………………. $100
Stock Radiator – ran cool………………………………….… $50 prefer local
Radiator hold down plate………………………………………$50
EGR valve and hold down…………………………………… $10
EGR solenoid bracket………………………………………... $SOLD
EGR solenoid – very low miles……………………………… $SOLD
Underhood light………………………………………………..$5
Flex duct (MAF TO TURBO) – no leaks…………………… $SOLD
Coil pack brackets …………………………………………..$SOLD
Charcoal canister …………………………………………….$15
Cruise vacuum ball…………………………………………. $SOLD
Misc cruise parts……………………………………………..$ask
Oil cooler adaptor …………………………………………. $SOLD
Air Cleaner scoop(86-87 Scoop for air breather) …………..$20
Air Cleaner assembly(86-87)……………………………… $SOLD
Small K&N breather for passenger side valve cover ……….$SOLD
Dip stick and tube …………………………………………. $SOLD
Serpentine belt (3000 miles)……………………………….$5
Main accessory bracket - the big alum. one ……………….$100
Frame engine mounts……………….…………………….. $SOLD
Rubber engine mounts(stock) – almost new……………....$35
Power steering pump……………………………………… $SOLD
Power steering reservoir ……………………………………$SOLD
86-87 Crank pulley with adapter………………….……….. $SOLD
86-87 Water pump pulley………………………………….$SOLD
Valve covers ……………………………………………..$SOLD
K & N Valve cover oil filler tube and filter(no rubber washer)...$10
Aftermarket valve cover filter(fits stock fill tube)………………$5
SUSPENSION / Rear drive train
Ask about front suspension parts…………………….……$ask
8.5 drive shaft……………………………………………… $50
Stock springs ……………………………………………….$10 each
8.5 posi rear – 67000miles……………………………….…$750 pickup
Control arms/suspension pieces…………………………..…$ask
Sway bars - front and rear ………………………………….$25 each
86 GN Quick Ratio Steering box ……………………………$SOLD
Passenger bushing heat shield (Kirbans, New)………………$15
INTERIOR
Dark Blue T-Type lower door panels – no CS……….$50.00 a set
Upper door panels - no chrome escutheons or pull straps $75.00 a set
Gray T-Type door panels – lower – CS2…………….$100 a set
Upper door panels – no chrome escutions or straps…$150 a set
Door sill plates ……………………………………………….$10
rear package tray – gray……………………………………… $35
B pillar covers…………………………………………………$35
used carpet – gray……………………………………………. $25
Emergency brake release mechanism……………………….. $25
Gas pedal ……………………………………………………….$8
Under dash covers …………………………………….$20 a side / $35 for both
Double guage ‘A’pillar (Lotek) 1 has been opened up to 2 3/8…$15
86 T-Type front seat belts – grey……………………………….$50
Shifter - no T handle ………………………….…………………….$35
steering column(tilt, floor shift car)………………………………… $100
Console shifter plate - goes around the shifter ………………………$35
Console - 86 T-TYPE – gray, has a few cracks on lower panel…..….$75
Dash plaque - 86 T-Type REGAL…………………………………….$35
Sail panels for Hardtop car ………………………………………….$50each
Seats 86 T-Type gray front bucket seats – one needs recovering …….$150
Steering wheel - good shape…………………..…………………….. $100
T-type horn center and ring – has crack………….………….…………$SOLD
Seat Track Covers – manual -pass side………………………………..$30
Seat Track Covers –manual -driver side …………….………………..$30
Gauge surround………………………………………………………..$30
Radio surround……………………………………………………….. $20
Grey third brake light………………………………………………….$20
Glove box ………………………………………….………………….$40
HEATER/AC CONTROLER…………………….…………………..$30
Visors - gray – recovered a while back, a little faded ………………..$20 each
Rear view mirror excellent shape ………………….……………….. $10
rear seat gray-both pieces ……………………….…………………..$100
Interior gray……………………………..……ask for other availability
BODY
Blackout headlight bezels(have screw hole in them for unknown reason)$SOLD
Right side air dam – good shape…………………………………………$25
Left side air dam – has hole cut in it for cold air………………………...$10
Rear air dam…………………………………………………..$20
Rear quarter panels – prefer local……………………………………$200 each
Doors- pretty clean, very slight rust on bottom – prefer local……… $200 each
Trunk Lid- small dent above lock area – prefer local………………… $100
Hood- rust free – prefer local………………………………………… $200
Clean front fenders – cut for GNX vents………………..………..$100 each
T-type header panel – perfect prefer local……………………………$150
Quarter window glass with black trim …………………………..$75 each
All black window moldings- ………………………………….$300 for all
Heater/Air box- great shape ……………………………………….$75
Radiator support- ………………………………………………..Make offer
Door glass………………………………………………………… $25 each
Front bumper – painted(I think)……………………………..…….$75
Rear bumper – painted(I think)…………………………..…….. $SOLD
Grill (86 T-type grill)…………………………………………….. $75 pending
Lock set(all 3 locks with key)……………………………………… $60 pending
Door mirrors ………………………………………..…………..$30 each
Black manual antenna complete with mast, base and nut……….$SOLD
Turbo plastic wheel wells……………………….………….. $80 each
Tail lights Harness …………………………………………….$35
Bumper light trim………………………………….…………..$20 each
Hood pop cable………………………………………………..$10
Hood trim - rear…………………………………………………$50
Trunk / hood latch ……………………………………………….$15 each
headlights ……………………………………………………..$1 each
Rear window to trunk filler……………………………………$20
Inner fender metal liners ………………………..…………….$30 each
windshield wiper assembly …………………………………….$25
Front under frame braces………………………….……………$SOLD
’Kirban’ Rear-seat braces – installed about 3 years, great co … $40 shipped pending
complete frame complete or can cut parts off - left side front frame horn a little tweaked
complete beautiful floor pan for bucket seats and console $100 – come cut what you want
TRANSMISSION
D5 converter …………………………………………………..$50
Transmission cross member – 200 4R………………………… $40
Tranny dip stick and tube………………………………………. $40
Speedo cable……………………………………………………$20 pending
Thanks, Rob
Thanks,
Rob Pahl
Keller Tx
captrob@hotmail.com
Misc:
Scan Tools
CHIPS
ENGINE
INTERIOR
BODY
TRANSMISSION
Thanks, Rob
