Has anyone ever noticed that when head is mounted that the cylinder area around the intake valve presents an area that seems to be a area that would present a obstruction to intake flow. It may seem hard to discribe but if when you have your next motor apart without the pistons in mount one head, flip block over and reach into that intake valve area and you'll notice a sharp corner and a ledge for incoming gasses to smack right into.The cylinder wall extends into the combustion chamber area (sharp edge detonation?)talk about flow obstruction.Even when and if you bore .030 over or..that area will still overhang into the combustion area. should we be relieving the block in this area? open for discussion. check it out.
