o2 and maf reading on powerlogger not reading rite
stevek
my o2 reading on powerlogger seems only to work in 1st gear the it goes down to .05 and stays there till i let off,also the maf readings at ft would go upto around 450 now it gets pegged out at 284 on powerlogger, my setting on powerlogger is set on 512 for extender chip, any ideas thanks , would the rjc power plate i installed have any thing to do with these lower readings
First off, what O2 sensor do you have. Let me guess, AC AFS-22.
The power plate has nothing to do with your issues....unless of course it was installed incorrectly and isn't sealed properly.
the o2 sensor ,im not sure what brand its is, #100591 is stamped on end where wire is the cylinder that comes from the nut to the whire is 3/4 inch wide and 1.5 inches long,i tried ac one, same thing happened so i put other one back in. the power plate put 2 gaskets on and put in the way the picture has it on there web page
