O2 sensor help at WOT?
Limited87
Hi guys, I am having a issue with my O2 readings at WOT all of a sudden on an 86 T. I have had 3 O2s in it now and they are all reading the indetical same thing. 2 of these were Caspers heated and now a stock one. The car just started doing this on the way to the track the other day, until then the car was like clock work.
It reads fine all the way until you hit wide open throttle then all of a sudden the O2 readings go to the basement with readings going from .790/.820 under 1/2 to 3/4 throttle to .03-.06 under wide open throttle. But still pulls fine and hard and has no knock. I have pulled enough fuel out of it to make it start to have some knock but still no o2 readings change under wot reguardless of the tune. I have checked the grounds on the back of the passenger side head, battery and still no changes. Also looked at the ecm for any loose wires, exc with no luck. I am using the same OTC monitor I have used for many years and have never seen this before on any of my cars.
Any ideas on what could be causing this?
I have made no significant changes to anything. I just checked the fuel pressure at wot and it never drops below 60 psi , rock solid! It currently has reds double pumps, so its obviously has an electrical glitch some where an not a fuel issue. Its like tuning blind with no o2 volts at wot, just watching for knock. :mad:
Any ideas on what could cause it?:confused:
Check the grounds at the back of the pass head again, most likely 2 of them are broken.
I know that is the problem, ive seen it a few times!!
BW
