James velez
CARPORN.NYC
- Feb 11, 2012
I HAVE A 1985' HOTAIR GN, BRAND NEW EVERYTHING!! MOTOR, COMPONENTS ETC. I ALSO, IN THE PROCESS OF RENEWING, UPGRADED TO 60LB-ERS, AND A COMPLETE 87' ECM CONVERSION IE: MAF, MAP, TRANSLATOR, IGNITION MODULE, IAT SENSOR AND A TT CHIP BURNED FOR THE NEW COMBO. HOWEVER, I DID NOT REPLACE ANY OF THE PRE EXISTING SENSORS AND HARNESS ETC. I AM NOW SINCE THE REBUILD HAVING A PROBLEM STARTING THE CAR. IT TURNED OVER ONCE AND RAN BEAUTIFULLY THE FIRST TIME WE TRIED, BUT SINCE THEN HAS NOT BEEN ABLE TO RESTART. IT JUST TURNS AND TURNS AND TURNS. IT WANTS TO START, BUT IT JUST DOESN'T. WHICH BRINGS ME TO MY REASON FOR REACHING OUT TO YOU ALL. MY BUDDY RAN AN OBD SCAN AND HERE WERE THE RESULTS:
- IAC- SYSTEM PROBLEM, CANNOT SET DESIRED RPM OR ISA- IDLE SPEED ACTUATOR, CARB SYSTEM PROBLEMS.
- ECM FAULT OR O2 SENSOR CIRCUIT FAIL (RICH LEFT/ LEAN LEFT)
- ESC- ELECTRONIC SPARK CONTROL CIRCUIT PROBLEMS
- EST ELECTRONIC SPARK TIMING CIRCUIT (LOW VOLTAGE DETECTED)
BEAR IN MIND NOW ALL THE PLUG WIRE CONNECTIONS , IGNITION MODULE CONNECTIONS AND EVERYTHING ELSE IS INSTALLED PROPERLY AND TRIPLE CHECKED. WE ALSO DOUBLE CHECKED CAM TIMING WAS CORRECT AND IT IS AND ATTEMPTED TO USE A CAM SENSOR TOOL TO MAKE SURE THE SENSOR WAS PROPERLY SET. CAM SENSOR TOOL LED WOULD NOT LIGHT UP WHEN TRYING TO SET. NOT SURE IF THAT IS THE FAULT OF THE TOOL OR THE SENSOR. TOOL WAS BRAND NEW OUT OF THE PACKAGE.
THAT ALL BEING SAID, I WOULD GREATLY APPRECIATE ANY ADVICE AND OR HELP AS TO WHAT MY NEXT STEPS SHOULD BE TO SOLVE THIS PROBLEM. THIS HAS BEEN A LONG AND FRUSTRATING ROAD RESTORING HER AND I KNOW I'M IN THE HOME STRETCH. PLEASE HELP ME OUT!!!!!!!! THANKS IN ADVANCE GUYS.
