The sensors have specific ranges of accuracy.
A bar being approx 14.7psi, is at sealevel, and is a factor when determining the capacity of the sensor you will need.
IE:
2 bar sensor has 1 bar used for reflecting vacuum. So, the sensor has 1 remaining bar of resolution, that will show boost up to approx 15psi.
A 3 bar will use 1 bar for vacuum, and allow 2 additional bars of resolution, or approx 30psi boost.
