OEM Timing cover.
X Ray
The GNX changed my life!
TurboBuick.Com Supporter!
This is a never run but modified timing cover. The oil feed inlet have already been modified and a spacer for a larger pump gear was installed. The cover was also powder coated. There is a black spot on the cover as you can see in the picture and it was installed on a previous build. You also get the spacer. You will need pins. $150 you pay the ride.
Is this a GM timing Cover? -aaron
if its a GM Cover [it looks like it but - ya never know.... ;)] - i will take it...-aaron
